First post, by Cozzie
Im on windows 7 64-bit, and i have everything installed correctly, my problem is that i cant use the keyboard shortcuts within the dos box. Like ctrl+f9 keyboard command should close the dos box down, but if i press ctrl+f1 it has no affect on de dos box, none of them do. Like on my keyboard f9 is the keyboard shortcut for highering the volume of my laptop. So wen im in de dos box window and i press ctrl+f9, all that happens is the volume is turned up, its the same with all the keyboard commands in the dos box.None of them have any affect that they should have. Any help would be greatly appreciated. Thanks
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
Press F-Lock on your keyboard.
Got nothing to do with dosbox.
Water flows down the stream
Reply 2 of 3, by Cozzie
Dere is no F-Lock key on my keyboard, i have a dell inspiron 1545 laptop, dere is an fn key here, but i pressed that when in the dos box and it still not working correctly
Reply 3 of 3, by Cozzie
Sorry just got it dere, i have to lock the fn function, tanks for ur help bud, appreciate it
