First post, by gaula92
Hello there
Is there any way to set mode-x games refresh rate within DOSBOX?
In the host side, I can only use certain refresh rate frequencies since I'm using a Linux framebuffer.
I've tried Univbe, but the Unicentr utility doesn't allow me to change refresh rates like I would on a real S3 machie. I've also tried Unirefresh1.42 and vbehz with no luck at all. So I'm starting to think about patching the code to force mode-x games into exact 60HZ refresh rate....
any ideas?
regards
