First post, by Hatta
I'm trying to set up my joystick for use with X-Wing. My joystick has an analog twist axis as "axis 2", the 3rd actual axis counting from 0.
X-Wing, by default, has Axis 0 as pitch, Axis 1 as yaw, And Button 1 + Axis 1 as roll. I'd like to assign Button 1 + Axis 1 to my real Axis 2.
I haven't been able to figure out how to do this. I'm using the FCS joystick type, as I'd like to use my hat too. I've added every Axis 2 and Button1 to every virtual axis in the mapper and none seem to work. Am I going about this the wrong way?
