First post, by nirhazir
I installed dosbox 0.74, and when i try to run it, it crashes.
i got somehow to prevent the window from closing, and it says:
"cant init sdl directinputcreate: undefined error"
i tried to change the "output=" as recommended on the manual, and it didnt work. all drivers are up to date.
my system is xp sp3,
core2 t5500,
intel gma950 graphics
thanks for your help.
Reply 6 of 11, by DosFreak
Old error 😀
http://niobium.mine.nu/~sunrice/ithp.cgi?chan … 31124&display=1
Mabye touchpad drivers are interfering?
I remember having an issue with Touchpad drivers and Vmware on NT4.
Make your games work offline
Reply 9 of 11, by vladr
Had the same problem with an XP SP3 Dell laptop. Updating DirectX didn't help either, and dxdiag also failed to enumerate DirectInput. So I rebuilt SDL without DirectX support and everything works. Extract the attached SDL.DLL over the one in the DosBox directory, and make sure you set the video config of DosBox to anything non-"direct".
    sdl.zip
    113.33 KiB
    418 downloads
Reply 10 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Did you try "SET SDL_VIDEODRIVER=WINDIB" ? I think it also has an effect on SDL's use of DirectInput, based on a few cases where it appeared to, but don't know if it will help with this problem.
