First post, by sapfeer
Hi there! I wonder if there a way to browse internet from DosBox... I tried to search the forum, but all I found is a reference to DosBox MegaBuild which runs only under Window, AFAICS...
Actually I'm just playing with so called "browser masquerading" and I would like to know how does Dos introduce itself to web-servers... There is no any really valid information at the web so I decided to go deeper and try to find out from the "source"... I know it's a bit weird, but I'm curious about it! 😜
Any help or comment is greatly appreciated!..
...any reference to source of information on how to set up such is also very welcomed!
Reply 1 of 5, by ripa
The user agent string is provided by the web browser. You can make your windows web browser tell the web server it's an Apple II computer. Or you could make your DOS web browser identify itself as Windows.
Reply 2 of 5, by sapfeer
Sure! That's I'm playing with and I want to know what are valid DOS web browser identities.
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
use bochs or something like that.
it might work with dosbox, but that is not intended
Water flows down the stream
Reply 4 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The only DOS-based browser I know of is Arachne.
I remember seeing a screenshot where h-a-l-9000 had Arachne running with his megabuild and appropriate packet drivers, but DOSBox is probably not the best platform for it.
