First post, by hps
Tried to use dosbox, everything fine when using dosbox as it comes out of the installer.
When i try to use it in a .bat file with ...dosbox.exe myExe -exit -noconsole ... 2 dosbox windows appear, one of them showing myExe; i can use myExe without problem but after exiting myExe the dosbox myExe was running in stays open, command prompt sometimes still active and i have to use task manager to kill both windows.
Does not seem right to me. Any Help appreciated.
Reply 3 of 5, by hps
Dosbox version is "0.74 windows";
exact contents of .bat file (one line):
"c:\Program Files (x86)\DOSBox-0.74\DOSBox.exe" c:\csoft\angeb\finzmath\fms.exe -exe -noconsole
Program comes up fine, but doesn't end so.
What's this funny stuff about "don't use it with vm-ware" ?
Could try it - but must get a real machine first. If you say that it is not usabe under vmware - no problem, i'll try with a real machine.
Reply 4 of 5, by DosFreak
You are running an emulator under an emulator. That's not supported.
DOSBox runs on all commonly used OS's. If you can run vmware on your host then you can definetly run DOSBox on your host.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
