Windows 7
First post, by Phulax
If I download & install a game from the Net I can easily play it through DOSBox. However, installing a came from my CDrom is apparently impossible in Win7. I can eaily do it on my old Win XP puter but not my new Win 7. Is anyone out there able to install on Win 7 using their CDrom?
Reply 1 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
dos games can be installed on W7 through Dosbox. Other methods are actually very unsafe and asking for disaster, even on older Windows.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 10, by Dominus
DOSBox Moderator
60 seconds guide to getting your game to run in DOSBox
Reply 5 of 10, by Dominus
DOSBox Moderator
if you can be specific about the game and post exactly what you are doing we might be able to figure out what's wrong...
Reply 8 of 10, by Dominus
DOSBox Moderator
Well you could have learnt something this way. But try it your way, just be aware that your way is probably give problems in the end when you try to play in dosbox...
Reply 9 of 10, by HunterZ
Installing a game using Windows and then moving it to another location to run in DOSBox is horribly over-complicating things. You can mount the CD-ROM itself directly from inside of DOSBox and install straight into your pretend DOS C:\ drive! That's actually the way you're supposed to do it...
Reply 10 of 10, by Phulax
Sometimes going though DOSBox doesn't recognize any drive I have like when I tired to install Fallout it brought up the FO install which did not recognize any drive. I had a buch of old games in my XP laptop I copied over to my larger Win 7 "Oldgames" file & DOSBoc has worked with them well enough........
