First post, by Emanuele
Hi all,
I'm Emanuele.
Thanx for all for help.
Now I have found the Shortcut keys for DosBox setting, but I must make it every time I start DosBox becouse I haven't the DosBox.conf file in my system.
Why?
Can I create it via Shortcut, after I have set all DosBox options, like CPU Cycle, FrameSkip, C mount point, etc. ?
Another question: best settings?
Another question: Why on my system sound card don't work?
My system is AmigaONE / SoundBlaster 128 PCI / DebiancPPC.
Bye and thanx and good work.
Reply 1 of 2, by parapente
You can create the missing dosbox.conf by using the command "conf -writeconf dosbox.conf" inside the dosbox. If you exit dosbox and look at the directory you where when you run dosbox, you will see the dosbox.conf file.
