First post, by sammyjammy
hey im new to this dosbox and i figure out how use it.
ok i bought brand new cd rom terminator future shock.
i follow instructions on how install it useing dos box.
1st. i type mount d d:\ -t cdrom
2nd d:\
3rd cd future_shock (came up saying more than 8 charecters try future~1)
4th cd future~1 (it said somthan like cant change name)
why??? what i do wrong??
after while i gave up that way and copy the files to my harddrive game folder so i redid the whole proccess over again but with c c:
this time it went through got to the end were it said congrats you install
future shock. now retype the words (below) and press enter after every line or somethan.
cd c:\games\shock
SHOCK
came up with anouther screen and it read
c:\GAMES\SHOCK
i type the word SHOCK and it came up saying
fatal make sure tfs cd rom is in the drive. why??
what am i doing wrong??
appreciate it
Reply 1 of 22, by telanus
How do you mount the game after Installation?
If for example you mount c c:\dosgames (never mount just c:)
mount d d:\
Install the Game, and when You start the Game make certain that you use the same mounts.
Or a better Idea would be to make a ISO outoff the CD , I use Isobuster without problems, Just make a raw dump
and mount it with "imgmount d c:\dosgames\cd\fshock.iso"
Reply 3 of 22, by leileilol
The Terminator: Future Shock CD shouldn't have a "future_shock" folder so disregard that stupid "how-to" guide you found
If you look at your CD which i'm sure you have, it'll tell you to type:
D: <enter>
INSTALL <enter>
The rest is self-explanatory. Please go through the install process instead of directly copying files so the game knows where to find the appropriate paths.
The only DOSBox related help you just need is mounting a C: for your drive (use a folder) and a D: for your CD-ROM. Personally I put the appropriate mounting lines on the end of the dosbox.conf file for ease
Reply 4 of 22, by sammyjammy
Dear leileilol
ok i see that on the cd.
I open up dosbox.
type:
MOUNT d: than press enter
it came up saying
usage MOUNT Drive-Letter Local- Directory
Fore example: MOUNT c d:\dosprogs
this makes the directory d:\dosgroups act as the C: inside DOSBox.
the directory has to exist.
Can explain what im spose do?
the only guide i read was off wiki but dat got me no were.
unless i use C:
appreciate it
Reply 5 of 22, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Follow the guide 60 seconds guide to getting your game to run in DOSBox
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 22, by Dominus
DOSBox Moderator
Read the readme and the guide I posted the link to. In the readme pay attention to the autoexec part.
Reply 9 of 22, by sammyjammy
ok i read it. but do i got keep going through reinstall proccess on future shock?
Also i know this not the fourm to ask but any one know good control i got one but wasn't enough buttons
Reply 12 of 22, by sammyjammy
nerver mine haha.
how do i set up dos box so that i dont got keep reinstalling terminator.
i set up autoexe on dos box. but how do i keep terminator install so i dont got keep reinstalling it?
i want be able open dosbox type the word SHOCK and terminator game comes right up
Reply 13 of 22, by Jorpho
What exactly is the problem? Just mount the same directories that you mounted when you installed the game. (It has to be exactly the same directories - if you mounted C:\Games or whatever as drive C when you installed the game, then you need to mount C:\Games as drive C, not some subdirectory like C:\Games\SHOCK. And if the game checks for the CD, then you'll need to mount the drive for the CD as well.)
As you already said, you just need to put the relevant lines in the autoexec section.
Reply 14 of 22, by sammyjammy
I did all that. really helps. but when dosbox comes up it opens tfs game but i got install it to my hardrive again chose folder i want install it in again regonfigure my sound card..again! basicley you get the point.
How do i install the game without going through all that?
Reply 15 of 22, by Jorpho
Your posts are kind of hard to understand.
sammyjammy wrote:
you get the point.
No, I don't, really. Why do you need to install the game again every time? There is no reason you should need to do this.
Reply 19 of 22, by Dominus
DOSBox Moderator
and actually additionally post your *EXACT* steps you do when you want to play Terminator.
