First post, by lucky7456969
Hi,
I have downloaded yoke, Timidity++
I have changed the midi device to Yoke
Setting everything in DOSBox according to the other threads.
But still no music.
Does anyone have links to general steps for setting up MIDI in win31?
Thanks
Jack
Reply 1 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
does it work with games so they use yoke? This is the first step to make sure midi is played through yoke before going at windows.
And then install the SB drivers as in my guide. This will by default set midi to the dosbox set midi port.
Reply 2 of 13, by lucky7456969
Hi Dominus,
Hummm.... I am not quite sure which games use MIDI. As I was using Dosbox under Windows XP, the drivers had all been setup properly, do I have to uninstall them, and then reinstall them once again?
Thanks
Jack
Reply 3 of 13, by kolano
lucky7456969 wrote:
Hi Dominus, Hummm.... I am not quite sure which games use MIDI. As I was using Dosbox under Windows XP, the drivers had all been […]
Hi Dominus,
Thanks
Jack
Typically there is a sound config executable included in the files installed by the game, usually named setsound.exe, setup.exe, install.exe or similar. You'll want to run that and reconfigure the sound options to use General Midi.
Reply 4 of 13, by lucky7456969
In Doom2, I can hear the music, what to do next? do I uninstall all windows drivers? No matter what I choose intelligent, UART, MUNT, ALSA, OSS, win32 etc, still got no midi (for example, afterdark as a test) or playing crayon.mid for experiment
Thanks
Jack
Reply 5 of 13, by Dominus
DOSBox Moderator
is the midi port in windows correct? (and midi volume slider actually not muted down)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 13, by lucky7456969
How to check? When I was setting the MIDI mapper, this messagebox comes up?
Thanks
Jack
    114.17 KiB
    132 downloads
Reply 7 of 13, by Dominus
DOSBox Moderator
first of all you don't want "SB16 ext Midi", you want "SB16 all Midi".
Also, you might need to install the Creative SB16 drivers again. You check the midi port with those (SoundBlaster Configuration Program)
Reply 9 of 13, by Dominus
DOSBox Moderator
don't try all midi ports, it needs to be the same you set in dosbox conf, by default 330.
What is your Windows setup? Is it Windows 3.1 or Windows for Workgroups 3.11? Also did you install Windows from within Dosbox or is it an older Windows installation you now use in Dosbox?
If you installed it in Dosbox, did you follow my guide? Windows 3.1x DOSBox Guide
Reply 11 of 13, by Dominus
DOSBox Moderator
Midi port 210-260? or Base io address?
Please give a screenshot and look at my questions I edited into above
Reply 12 of 13, by Dominus
DOSBox Moderator
Where do you get that Windows Sound Blaster driver version number from?
