First post, by healie
I'm here because I looked all over the web and I followed the tutorial of how to mount a drive on the mac OS X to a T and it simply will not mount.
I put the "Dosgames" folder in my Home directory with the game files inside.
I put in the command Mount C:/users/[my username]/Dosgames.
It says "This makes the directory ~/dosprogs act as the C: drive inside DOSBox. The directory must exist."
Now I'm not very skilled in this sort of thing, I picked up DOSbox in passing pretty much. It works just fine on my virtual machine, but I've tried several different directories on my machine and I don't know enough to figure out why the hell this isn't working myself. 😜 And I tried to look up some troubleshooting tips, and one was talking about mounting a root drive or something...I typed that command in and it said the same thing as above.
I haven't messed with any of the preferences/configuration files.
I just read that this info is needed for people trying to help, I'll give what I know!
Macbook Pro:
-Operating system: Mac OS X 10.6.6
-Processor: 2.4 GHz Intel Core 2 Duo
-Memory: 4GB 667 MHz DDR2 SDRAM
-And I did read the Readme file, although it wasn't much help.
Reply 1 of 6, by bloodbat
If you copied and pasted your mount command, you're missing a space and have a colon that shouldn't be there.
Try:
mount c /users/[yourusername]/Dosgames
or
mount c ~/Dosgames
Do keep in mind that Unix is Case Sensitive
Reply 2 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
If your username has a space you need to put the path in quotes
For example:
Mount c "/users/my username/dosgames"
Or as bloodbat wrote use
Mount c ~/dosgames
@bloodbat, OS X is by default case insensitive
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 6, by healie
Everywhere I read it said that DOSbox does not recognize the ~ for your home directory on a mac.
And my username does not have a space.
EDIT: Putting it in quotes fixed the problem! TY. (My username is just my real name, rachel, which has no spaces, so I don't know why the quotes were needed!)
Reply 5 of 6, by Dominus
DOSBox Moderator
Probably the quotes weren't the problem, the missing space and the extra : were the problem...
~ DOES work. Why trust sites when you can just try and get the positive result in a second?
Perhaps that didn't work for very old versions of Dosbox, sites tend to not fix their no longer true stuff
Reply 6 of 6, by dada
The ~ directory works just fine on Mac OS X. In fact, I think it's tedious to use it. I always make a new directory called C in the DOSBox program directory and then add
mount c ./c
to my autoexec. Works fine.
