First post, by sorbit_4
I use DOSBox v0.72 under XP. I have a DOS program which uses the speaker. I can not configure DOSBox to have the sound on the speaker. The sound alwais go to the soundcard which is integrated in the motherboard. Under XP (and under MS DOS) in command mode the sound goes to the speaker.
How can I reach the same effect under DOS Box?
