First post, by Marting
I am testing DosBox on Windows 7 (64 bit) to run one old GWBasic application. This application needs correct date and time to run properly. The Windows system is synchronized from network, but I cannot change time of the application in DosBox, because DosBox doesn't monitor time changes of system.
Is there any solution to read date and time without restarting DosBox?
