First post, by mrugesh
Hello,
I've downloaded DOSBOX 0.74 and ran the C program. It works nicely but when I try to display it by pressing CTR+F9 it just shuts the DOSBOX down & comes out on the desktop.Then I have to again go into the DOSBOX and again repeat all the procedure of mounting and commanding.
What to do?How can this problem be rectified? [/b]
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You need to remap keys it seems. Ctrl+ f9 is the shut down combination of dosbox.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by mrugesh
I followed the documentation but it didn't help.What to do? dosbox window just shuts down. also I try to run a C program by run tab it shows message "Not an EXE: Hello.LIB". what to do.
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
What to do?
Works fine here. Try again.
That's completely unrelated to dosbox. Read the manual of the compiler.
