First post, by Dossy
Okay. So i've read the manual, about 10 times now, and i've google searched for about 3 hours straight, and I cannot find out how to get multiple .conf files to run for Dosbox 0.74.
I read from the manual Dosbox -conf <configfilelocation> will run that .conf file. So i've done tried, in the target location from the desktop icon,
"C:\Program Files\DOSBox-0.74\DOSBox.exe" -conf C:\Program Files\DOSBox-0.74\mech2.conf
I've also tried running it from cmd.exe. I get the same result everytime... Dosbox loads ONLY from the main .conf file.
Is there any way I can run multiple .conf files for Dosbox 0.74? And if so please let me know... I am mentally exhausted at this point from working at it and getting no results. Thanks.
Reply 1 of 3, by Gamecollector
You must use "" with your .conf name.
Try dosbox.ece -conf "C:\Program Files\DOSBox-0.74\mech2.conf"
Plus, by default, dosbox search the .conf file in the work directory, so -conf "mech2.conf" must work too.
P.S. all above is for Windows system, not sure about *nix or MacOS.
Reply 2 of 3, by Dossy
Yea, thats what it was. FINALLY WORKS 😁
The Target line has to be, "C:\Program Files\Dosbox-0.74\Dosbox.exe" -conf "C:\Program Files\Dosbox\Mech2.conf"
I was trying the quotes this way, "-conf now I get it. It's just the quotes around the path.
Thanks for the awesome help 😁
Reply 3 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Easy rule: if you have a space in your path you need to put it into quotes. Most programs can't handle spaces
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
