First post, by Justnet
I run one program with DOSBOX but size of the window is too small. I wanted to know if is possible to adjust the dimensions of the window of DOSBOX.
Thanks
S.O. Windows 7 Ultimate 64 bit
DOSBOX 0.74
Thanks
DOSBOX 0.74
1. OK, I find dosbox-0.74.conf file, but changing scaler from normal2x to normal3x don't change window size?
2. Second question: Manual says to move config files to another location. Where can I configure the location of the config file?
Can you help me?
Thanks in advance.
1) run a game. the prompt doesn't scale
2) ignore that if you only want to mess with the scaler, else -conf
Water flows down the stream
Thanks, but my dos program not a game and I need to change window size without FULL SCREEN.
Thank you for your patience.
add forced to the scaler line (as is documented)
Thanks, I done , it's that.
Regards
