First post, by Muyfa666
I have TR1 running good in DOSBox, but I wanted to try out the unofficial audio patch.
The patched tomb.exe can use parameters to chose audio options. How would I use this with a .bat-file I made for DOSBox?
My .bat-file looks like this:
dosbox.exe "tomb.exe" -noconsole -fullscreen -exit -c "imgmount d c:\tombraid\disc\tr1_uap.cue -t iso"
Where and how shall I put the -audio 0 parameter?
dosbox.exe "tomb.exe" "-audio 0" etc, or dosbox.exe "tomb.exe" -audio 0 etc?
Anyone have a clue?
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Write a new batch file (tr1.bat) with tomb.exe -audio... In it and save it in the same folder as tomb.exe. In the line where you start dosbox with the tomb.exe, replace tomb.exe with tr1.bat
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 5, by Dominus
DOSBox Moderator
You're welcome. Easy solutions sometimes need to be pointed out 😉
Reply 5 of 5, by Dominus
DOSBox Moderator
*I* have no clue 😉
I rarely use the command line for other thibgs than using a different config file. I rather have one mount for all games and specific game settings in a start.bat in each game folder...
