First post, by Tim
Hi all,
Can anyone help out on this? I've got an HP PC with Windows 7 and using DOSBox I want to run Championship Manager 2. I can mount the CM2 folder fine but it wants the CD in the D:\ drive. If I put the CD in my computer it still doesn't find it and if I use mount d d:\ -t cdrom that works ok but when you look at D:\ it shows the D:\ drive on my PC which is the HP recovery area.
Basically I can't mount D:\ to be the CM2 CD no matter what command I try, I always get the HP recovery area so what can I do to get CM2 on D:\? The program won't run if I mount the CD elsewhere, it has to be on the D:\ drive.
Cheers
Tim
