First post, by Gabriel
Hi,
I'm writing you because I've installed Windows 3.11 for Workgroups and I have problems with the games based on Win32s.
I install those games but when I try to execute them an alert appears to me about a DOS 21 Error.
How can I solve it?
NOTE -> I've read all the guides before and during the process.
Thanks in advance.
Reply 2 of 4, by Gabriel
If only you could read in the same way as you make yourself the funny man ... I've said that I've been several hours reading guides and possible solutions. I found this solution but it doesn't work for me. Because of it I ask here. But you only wanted to say the joke. Typical.
I will ask in another site where one treats me with more education than here.
Reply 4 of 4, by bloodbat
Actually you never said *which* guides and I assumed you meant the ones *here*; I won't even get into the semantic difference between *all* and *several* 😀
