First post, by ohiwastedmylife
I tried searching around but did not see anything relating to this issue. I recently got dosbox Turbo and have been running a ton of games and built up a large library. I also recently flashed a new ROM on my device and when I reinstalled dosbox Turbo none of my profiles showed up. I looked on the SD card and all the profile .conf files were still present. Is there an easy way to backup profiles completely for transferring to other devices or in my situation running a new ROM? I am getting a new phone in the next month and I do not want to even use dosbox except for a few games since it will be wiped again. PS I do not mean Titanium backup I have that and most likely will not have ROOT access for a while on the new device since Verizon enjoys locking bootloaders. Thanks & sorry if repost !
Reply 1 of 1, by Jorpho
That's probably because DOSBox "Turbo" is not an official port. You should ask wherever DOSBox Turbo is supported.
