First post, by code120
Hello, I've a problem with yhkwong's build in that the keybord is too sensitive. In normal DosBox (and gulikoza's build) when a key is kept pressed there's a relatively long delay between the first sent input and the next ones. In yhkwong's build this delay is very short, and it's very easy to accidentally send 2 inputs instead of 1 (like moving 2 steps at once or turning 180 degrees instead of 90 in games like Eye of the Beholder). Does it depend on my settings (but it happens also on default settings) or can it be corrected in some way? Thanks
