First post, by wilder
does dosbox work/emulate 16 bit on win 8 64 bit?
Reply 1 of 4, by mr_bigmouth_502
It won't run 16-bit Windows apps straight-away, if that's what you're asking. You can however install Windows 3.1 on it and run 16-bit Windows apps through there though. Although, if the program in question is a Win9x app with a 16-bit installer, then you have to start looking into "proper" VMs that can run Win95/98, as DosBox doesn't support those very well (officially it doesn't support them at all even). 😜
Reply 2 of 4, by dosquest
I think his original question was "Does DosBox work on windows 8"
Doom isn't just a game, it's an apocalypse survival simulator.
Reply 4 of 4, by eL_PuSHeR
[Thread moved to DOSBox General Section]
