First post, by louis.c
Hi
I just got started with DOSBOX 0,74 on Windows 8.
I needed it to play warcraft 2.
I run the install without a problem but after that, when I close DOSBOX, I can't find a way to launch WAR2. I need to install it all over again.
I know you can install an autoexe in the configuration file but I cant find the file anywhere in the C:\Program Files (x86)\DOSBox-0.74.
Thank you
