First post, by mtkzz
I have a program that i run it in DOSBOX
this program is running by external device, the connector between program and device is ISA Card
but program and device can not connect because DOSBOX dose not recognize the ISA card
what can i do to deal this problem ?
my windows is XP
Reply 3 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You probably need a real dos machine. Some dos bootdisks may be enough
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 6, by Dominus
DOSBox Moderator
I bet there is some kind of screenshot tsr which you xan use in Dos to print the screen to file and later print these files. Otherwise I see no real way to do it.
