First post, by The3Seat
Using 0.74 on both i5 Laptop and Atom NetBook. After boot, any key that I press just repeats on the i5 but has always worked fine on the NetBook. After the repeating begins, then no other keys work and I can't Ctrl-C, have to close the window.
Th only other obvious difference between the machines is that the i5 is running 64-bit Win 7 and the NetBook is running 32-bit Win 7.
Any other ideas?
Reply 2 of 3, by Gamecollector
Happens on my P4/Xp system with hyperthreading disabled.
Reply 3 of 3, by The3Seat
Aha! I figured it out. It appears that this issue is the result of running the Synergy computer sharing service. When I stop Synergy the character doesn't repeating and typing continues normally and a repeating character stops if it was already repeating.
