First post, by andmm
Hello everyone.
I have no problem getting my games to run on dosbox but I'm having some problems setting up multiple dosbox shortcuts for a few games.
The problem is that different games are acessing the same dosbox config file even though I point to a different path.
So when I edit the config file por a particular game, with specefic autoexec commands for that particular game, the other shortcuts run the same config file that was set for another game and that doens't work.
So, I'm pretty sure I'm doing something wrong with my shortcuts command line parameters.
What's the proper way to set up a shortcut and how can I make multiple config files for each game? That's pretty much it.
I'm using Windows 7 and the latest version of DosBox.
Thanks for the help.
