First post, by squiddt
Hi,
I have the sUSB Side winder joystick installed properly on windows. In dos game EF2000, the joy stick is seen. I cannot calibrate it right. The plane will keep spinning and dive down to the ground with no response to joy stick input. I need help to map the axes on key mapper. Please, any help is appreciated. I do not know how to use key mapper for this joy stick. Thanks
