Kerr Avon wrote:Sorry, I can't help, but I have to ask, when did (and how) it become possible to run Windows 95 under DOSBox? I thought DOSBox didn't emulate something(s) that Windows needed to boot?
It is in fact even possible to get Windows 98 running, and with Voodoo emulation there's even Direct3D. There are many, many threads on the subject already. But, as noted above, this is not officially supported and probably never will be.
The major limitation is that Windows must be booted from a hard drive image (2 GB or smaller) and that CD-ROM support is only available if you use Daemon Tools within Win9x to mount an ISO stored on the hard drive image. Considerable progress is being made on this front (principally in the DOSBox-X branch).
