First post, by eadmaster
I'm trying to mount a cue sheet mixing an iso and a multi-track flac:
FILE "data.iso" BINARYTRACK 01 MODE1/2048INDEX 01 00:00:00FILE "audio.fla" WAVETRACK 02 AUDIOINDEX 01 00:00:00TRACK 03 AUDIOINDEX 01 07:12:30TRACK 04 AUDIOINDEX 01 10:10:14TRACK 05 AUDIOINDEX 01 13:07:12TRACK 06 AUDIOINDEX 01 17:44:43TRACK 07 AUDIOINDEX 01 20:48:29TRACK 08 AUDIOINDEX 01 25:18:08TRACK 09 AUDIOINDEX 01 29:38:68TRACK 10 AUDIOINDEX 01 32:48:19TRACK 11 AUDIOINDEX 01 37:39:45TRACK 12 AUDIOINDEX 01 40:19:68TRACK 13 AUDIOINDEX 01 42:58:10TRACK 14 AUDIOINDEX 01 46:30:30TRACK 15 AUDIOINDEX 01 49:00:40TRACK 16 AUDIOINDEX 01 51:46:39TRACK 17 AUDIOINDEX 01 52:11:09
According to the docs it should work, but when i try to mount i get on stderr
[..\..\..\..\src\libmpg123\parse.c:802] error: Frame size too big: 9491[..\..\..\..\src\libmpg123\parse.c:802] error: Frame size too big: 9491[..\..\..\..\src\libmpg123\parse.c:802] error: Frame size too big: 9491[..\..\..\..\src\libmpg123\parse.c:1073] error: Giving up searching valid MPEG header after 65536 bytes of junk.Note: Illegal Audio-MPEG-Header 0x00000000 at offset 65593.Note: Trying to resync...Note: Skipped 1024 bytes in input.[..\..\..\..\src\libmpg123\parse.c:1154] error: Giving up resync after 1024 bytes- your stream is not nice... (maybe increasing resync limit could help).
on stdout in dosbox:
MSCDEX: Failure: Invalid file or unable to open.
