First post, by offtheheezay
Does anyone know how to make a shortcut for games without needing to type in the autoexec for each different game you want to run
atm ive set up a shortcut using autoexec and Targetting the conf and exe's but if i want to play a different game i need to change it every time i want to launch a different game? help plz
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
In the autoexec keep a general mounting for c.
In rhat folder keep batch files with the needed commands for running your games.
Batch files are text files wiith the file extension bat.
Example
in autoexec:
Mount c c:/dosgames
There you have the batch file game.bat with the content:
Cd game
Game.exe
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
