Add to Docs
First post, by Guest
Ok, I wouldn't know if this was a common problem, but the first game I tried to run had a lot of problems with the 256 vga palette. Searching on the forum I found that I can add the parameter /g:bios to the command, and that should work.
Add to the FAQ in the readme.txt file
Q: My game's graphics looks strange, what is the suggested solutions?
A: Try /g:bios as a command line parameter, or go the the forums page of dosbox and ask your question here. (www.vogons.org)
I am not 100% sure what the url is here. 😀
-Canderel
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
this is for one game only (starcon 2) We don't know of any other game effected by this
Water flows down the stream
