First post, by Marcel de Reus
Hey guys,
I recently start using DosBox and I really like it. I had to run the CVS version because of an alsa compilation error, but the CVS compiled and runs fine.
But I kept a problem, no-midi device could be openend. After some research at this forum and google, I did the following things:
* compiled the snd-virmidi module and load it with the snd_index=1 parameter
* edited my modules.conf to set up the virtual midi card properly
* compiled fluidsynth
* searched for a soundfont and found (ffantasy.SF2) one.
* runned 'fluidsynth -m alsa_seq -a alsa /etc/midi/ffantasy.SF2'
* runned 'aconnect 72:0 128:0'
* edited the DosBox config file to 'device=alsa' and 'config=72:0'
Now DosBox says that he succesfully opened an ALSA midi-device so I think that part of the story works?
But my problem (stuttering sound) wasn't solved. The sound remains really poor. I changed the blocksize to 4096 but also that doesn't help. I tested it with various games as Monster Bash, Keen, Prince of Percia, etc.
My questions is offcourse, how can I fix te sound?
Thanks a lot in advance.
PS: Does someone here know how to get fluidsynth so far that its doesn't display his shell (the -i) optie and doens't quit immediately either? Because if I run it with the -i option port 128 won't be there.
PS2: Where can I get a better Soundfont? Wich are you guys using for example?
[edit]
BTW it's an laptop with an AXP 2200+, 512MB DDR, VIA KT333 board and an ATI Radeon Mobility 9000. Should be enough 😉
Time is the best teacher, unfortunatly it kills al it's students.
