Reply 40 of 43, by Spaz
wrote:Isolated the bug within the menu code itself. I believe, not positive yet, that the cycles updating in the menu bar is causing the midi bug. To test this, run Ykhwong's build of dosbox with cycles=max, test the midi, then change to cycles=25000, and then test the midi again. It seems like fixed cycles avoids the midi bug, but I believe it's actually the menu bar updating the cycles.
If not, then I will continue exploring the menu code for hints.
Yes, I can verify that cycles=max equals no MIDI. With fixed cycles MIDI works every time.
