mscdex
First post, by ViLe
how i can use mscdex on dosbox? it just says: "incorret dos version" and doesnt work.
Reply 2 of 11, by ViLe
If i use mount x x:/ -t cdrom, it doesn't work on games what check is there a right cd, for example rayman 1/gold. It says that there is wrong disk in drive. I have tested it (rayman) in real dos and it works with the cd but i want to hear sounds.
sorry about my english i'm a finnish guy 😉
Reply 4 of 11, by MiniMax
Rank Moderator
Moderator
ViLe, from a real command prompt, do a
C:> vol X:
to check the label (the name) of the CD. Then in DOSBox, mount it using the extra -label cd-label option.
_________________
Reply 6 of 11, by Mephisto
how did you get the rayman-cd working ???
in my case the cd is allways kicked out of the cd-drive with the message :
if the setup could not find raymans cd, press ESC and rerun
(FUCK) how did i get it working ??????
Reply 7 of 11, by Mephisto
sorry for the uncompleted reply:
Ive got dosbox 061
ram @ 64 MB
ems & xms on
sound set to 22050 khz
cycles @ 12000
ive tried it with the "label" & "ioctl" option - nothing worked, when i make
"dir d:" - thats my mounted cd-rom,
the volume name is d.\ (and not RAYMAN as in windows) , so anyone HELP ME !!!! please !!!
Reply 9 of 11, by Mephisto
Be Self Dunno, and go back to the "planet" where you came from.
and: what does dosbox got to do with the pc-technician ??????
btw, ive got it working by myself. 😈
Reply 10 of 11, by Guest
Hey guys!!Then how do u type the command??
I type
mount d: f -t cdrom usecd 970731_1118
where d: is where my game installed, f: is my cdrom,
but i get the message: f directory not found
WTF.......what's the problem??
please....dun ask me to refer to the readme,i refered it lots of times
still have no idea wat the fucker saying......
