First post, by czub
Hi.
nitro# setenv SDL_VIDEODRIVER vgl
nitro# dosbox
Exit to error: Can't init SDL No available video device
nitro# uname -a
FreeBSD nitro.netbsd.pl 5.2.1-RELEASE-p1 FreeBSD 5.2.1-RELEASE-p1 #5: Mon Mar 15 23:18:11 CET 2004 michal@nitro.netbsd.pl:/usr/obj/usr/src/sys/nitro i386
nitro# cd /usr/ports/devel/sdl12/
nitro# cat pkg-message
Your SDL library has been built with libvgl support, which means that you
can run almost any SDL application straight on your console (VESA 2.0
compatible videocard is required). To do this you have to enable VESA
support in the kernel by adding "option VESA" into your kernel
configuration file and set environment variable "SDL_VIDEODRIVER=vgl".
Good luck!
Any ideas?
