First post, by Guest
the keyboard seems to work inconsistently in particular with keyboard combos such as ctrl- alt- or shift- keystrokes in a game. The keystrokes might work, but after playing for a few seconds, (or maybe minutes) they stop working. e.g. in prince of persia 2, alt-l to load a game or the combo for quitting works at first, but after a while, all key combos like this stop working. this occurs in dosbox (i am using 0.61). Any help is appreciated.
Reply 6 of 9, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Just to clarify: reading the above mentioned it seemed to be only a game specific problem in Prince of Persia 2 (possibly fixed(?) in 0.63 - I did not test it myself)
Mirek
Reply 9 of 9, by Peter Swinkels
I have been having similair problems in DOSBox 0.65. Prince of Persia II doesn't work properly when started with the "makinit" command line option (which starts the game in cheater/trainer mode.) One of the things that happen is that the prince looses all of his health when trying to move to the left.
EDIT: Solved.
