First post, by MonkeyforaHead
Like the title says, that's my problem. Personally speaking I've got a computer with four hundred-something RAM, 900 MHz, a 32 MB graphics driver... okay, so it's not really fast, but I've also tried it on my friend's computer (2+ gigahertz, 64 MB graphics driver, and nearly double the RAM), and DOSBox runs just as slowly. Most non-graphically-intensive games will run alright, but when you get into things like System Shock and Jazz Jackrabbit, it crawls like molasses. 😖 Upping the frameskip does help a bit in some cases, but I don't know what would be the best setting for the "CPU" rate... and would that make much difference anyway, or is there something else I can do to improve the speed?
