First post, by sodaddict
Just so we're clear; i am a noob at DOS coding and what not.
I am trying to install 3DFX onto DOSBox so i can run GTA 1 in 3DFX mode, but i've tried every way possible and i always end up failing with the "unable to find DLL" error. No luck trying to find my problem or anything else on google.
I need help installing 3DFX onto DOS, in the most simple and easiest way possible.
