First post, by IBM Portable PC
Is it possible to run DOSBox in BSD/Unix text (console/tty) mode now?
If it is, ideally I would like to also try dosbox with https://github.com/shellinabox/shellinabox which uses java, and a built in mini ajax webserver, to serve any command line tool as a web page. It works incredibly well with SSH and telnet etc.
