First post, by dosboks
This is my first posting. I am more interested how midi applications can or can not run via dosbox. Not knowing much about dosbox, wanted to ask it here, after reading some midi in questions from 2007 and 2011. So is it true midi in is not supported in dosbox at all? This would mean, you can not play from your midi keyboard and record midi notes into a dos midi sequencer like 'texture' which I would like to test eventually?
Which other methods would you recommend which is similarly elegant or easy to run, lightweight and can run texture, plus with midi input? Thanks in advance.
