First post, by Guest
After running a certain program 5 times I get an out of memory error. I have bumped up the memory in the conf file and I still receive the error at the same exact point. I have also ran this on a different physical machine with the same results.
Even if there is a memory leak in this program, shouldn't the memory be released when it exits?
