First post, by ux-3
I am wondering if there is a test program available? It should assist the user to find out if the dosbox functions as it should. It would basically be a check if the dosbox and the local hardware interact propperly. It would check different audio outputs, screen functions, glide(?) etc. Call it a diagnostic, if you wish. It would be set to function on a clean install.
Right now, if something dosn't work, one can't be sure if it is a problem of the game, the emulator or the hardware. For instance, I am not sure if my computer plays music or only FM sounds, since I lack music in Warlords2.
Perhaps there is a know diagnostic. If so, please be so kind and provide a clue or link.
Thank you.
