First post, by polygonfuture
Hi everyone!
This is my first post so pardon my newbie status.
I am working on an art installation part of my MFA at UCLA. I am re-creating an office from the 1980s, using vintage office equipment. All of the computers, equipment, keyboards are alive and working with people (keyboards printing themselves, computers running terminal commands, etc)
I have an Epson FX-85 I am attemping to print using a super simple QBASIC / BASIC program.
The printer prints perfectly using the DOSBOX-SVN-LFN build using simple dos commands (EX. DOS > LPT1 )
However, when I attempt to print using QBASIC, I am told that it cannot find the printer:
52.25 KiB
52.25 KiB
Does anyone have any suggestions or thoughts? If not, can you please direct me where I mijght be able to find answers?
Cheers,
Jonathan
    46.4 KiB
Reply 1 of 9, by collector
DOSBox does not have printer support. You will need to use an experimental build of DOSBox, or better yet try vDos. https://sourceforge.net/projects/vdos/
Reply 2 of 9, by polygonfuture
As mentioned in my post above, I am using a build of dosbox which allows printing.
I can print out a directory using the command DIR > LPT1, but the LPRINT command does not work in qbasic.
Reply 3 of 9, by gdjacobs
If you have special functionality you have questions about, please contact the maintainer of that version of DOSBox or the author of the printing patch, whichever is easier. Alternately, have a look at VDOS as recommended by collector. It's built to run vintage office software.
Reply 4 of 9, by Wengier
QBASIC will *not* function properly in vDos because vDos lacks keyboard INT9/IRQ1 support. You are recommended to try vDosPlus (vDosPlus.org) instead. vDosPlus has *all* features of vDos plus many many more.
P.S. I am the maintainer of both DOSBox SVN-lfn and vDosPlus. The printing support in DOSBox SVN-lfn is relatively basic; for advanced printing support you are strongly recommended to use vDosPlus instead of DOSBox SVN-lfn in this case, and in recent days I am more focused on vDosPlus developments. Hope this helps.
Wengier
Reply 5 of 9, by gdjacobs
Hey, Wengier! Does vDosPlus add any build dependencies over DosBox which are WIndows specific? I'm curious if a build could be developed for other platforms, time depending.
Reply 6 of 9, by gca
Well, thought not 100% relevant to the original question there is a dedicated Windows version of QBasic called QB64 ( http://www.qb64.net ) which should do printing if your desperate. It even makes stand alone exe files (which QBasic cannot, as its a cut down version of Quick Basic).
Reply 7 of 9, by Wengier
Hi gdjacobs,
Like vDos, vDosPlus is a DOS emulator for Windows, so yes it has Windows-specific functions and will not natively work for other platforms (vDosPlus will run on Windows XP+ or even Windows 2000 while latest vDos will only run on Windows Vista+). However, vDosPlus can indeed run on a different platform like macOS with the help of programs like Wineskin Winery. For example, a vDosPlus package for Mac made by Edward Mendelson can be found from here:
https://www.freelists.org/post/xywrite/vDosPl … ged-for-the-Mac
Hope this helps.
Wengier
Reply 8 of 9, by gdjacobs
I haven't tried it under a compatibility layer like WINE. I was wondering if it requires any higher level toolkit, like MFC, or if it was similar to DOSBOX and used cross platform libraries throughout. Even if MFC is used, Winelib might be an option.
https://wiki.winehq.org/Winelib
Just trying to get a sense of things.
