First post, by ^SeFiRoT^
How do you set DosBox as the MIDI-Yoke output application? I understand that the recording application is set to input to record the MIDI, but audio recording applications have a box to set the midi device you want to use, but in the case of DosBox where do you set it up?
Thanx!
