speed up the cpu
First post, by eddyq
When I loaded DOS Box I say something that said I could use F11 and F12 to adjust the speed of the computer. But when I use those F keys it brings up a map of the keyboard. Also my program requires the use of ctrl/F1 but that also brings up the map. How can I use F11, F12 and ctrl/F1?
Reply 1 of 3, by eL_PuSHeR
[Thread moved to DOSBox General Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by zirkoni
In DOSBox:
Ctrl+F1 => opens DOSBox keymapper
Ctrl+F11 => decreases CPU cycles
Ctrl+F12 => increases CPU cycles
You can modify all of those keyboard mappings in the keymapper.
https://youtube.com/@zirkoni42
Reply 3 of 3, by Gene Wirchenko
zirkoni wrote:
In DOSBox: Ctrl+F1 => opens DOSBox keymapper Ctrl+F11 => decreases CPU cycles Ctrl+F12 => increases CPU cycles […]
In DOSBox:
You can also use the cycles command to set the cycles to a particular value. This can be done at the DOS prompt or in the autoexec section of the DOSBox configuration file.
Sincerely,
Gene Wirchenko
