First post, by mdavid
Hi, need some direction.
I've installed DOSBox MegaBuild 6 to run some legacy dos software - not games. I need to print from within DOSBox and understood from here https://dosprn.com/faq.htm#25 that I could use DOSPRN. I've installed DOSPRN into the DOSBox Mount directory, but when I try and print using DOSPRN command-line options - C:\UTL\DOSPRN\DOSprn.exe C:\USER\S997\Input997.PRT I get error "This program must be run under WIN32"
Is it possible to use DOSPRN like this within DOSBox? If so, what am I doing wrong? Are there other alternatives for printing within DOSBox?
Any help much appreciated.
David
Paddling upstream searching for the source
Reply 1 of 4, by JosSchaars
DOSPRN is a Windows program, it can’t be started from inside DOSBox (MegaBuild 6).
You would have to setup your program to print to a file, then let DOSPRN monitor the print files.
You could have a go with vDos, eventually you can still use DOSPRN for printing if vDos own print processor isn’t adequate.
Reply 2 of 4, by mdavid
Thanks very much Jos for your quick response, I'll give vDos ( or vDosPlus) a go after I get some sleep.
Reply 3 of 4, by mdavid
Hi Jos, I'm trying to use vDos, I need to download the DOS APPEND command for MSDOS-5.0 - do you know where I can find it?
Thanks
David
Reply 4 of 4, by _Rob
You should be able to grab any DOS utilities you need from FreeDOS. They should run under DOSBox.
Also, if your trying to run real MS-DOS utilities, you can get around the version problem using something like "VER SET 6 22" to make the program think your running MS-DOS 6.22
