First post, by Blackfire74
Hello, is there a way to remove special keys mapping? I use Norton Commander under DOSBox and I cannot use its own special keys combos like Ctrl+F2. It doesnt work at all in Norton Commander
wrote:Hello, is there a way to remove special keys mapping? I use Norton Commander under DOSBox and I cannot use its own special keys combos like Ctrl+F2. It doesnt work at all in Norton Commander
I can't believe nobody replied to this.
Run DOSBox and then press CTRL-F1 to open the key mapper. All of the special functions will be listed in a block on the lower right. Click on each one to see what key is assigned to it, then click the DEL button to delete it. When done, Click the Save button to write out a new keymap file.
If you ever need to restore those keys, just delete the .MAP file that it writes.
