First post, by missling
Running the 0.74-3 DOSBox.app on Mojave (10.14.5) returns a "package is damaged" error.
If I go into the package content and run the actual binary, it works. Still though this should be fixed.
Reply 3 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
very odd, I cannot reproduce this. it might be due to some certificate problem and/or the security settings on your mac to only allow App Store apps.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 6, by Dominus
DOSBox Moderator
Actually seems my buildbot was not having the updated certificates anymore and all my VMs, main machine and buildbot just accepted it without throwing that error.
I was now able to reproduce the problem in another vm and also to verify that a new build is working correctly. Expect a new version shortly.
Thanks for reporting this!!!
Reply 5 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
the new build (with same name) is up.
new sha1: 30bba3fadd50e98a67c9c8bb9fee076173226350
Water flows down the stream
