Reply 20 of 27, by gdjacobs
- l33t++
This is with DOSBox SVN, 0.74-2, or a third party build?
I'm using the 0.72 build.
Use the latest from dosbox.com
I don't know if there are wrappers that are set up with the latest version.
Okay, I tried the scaler=normal2x forced again, but in a different DOSBox wrapper that I presume runs a newer version of DOSBox. When I choose Battlespire, the screen is super zoomed in and the colors are all messed up.
We don't support "wrappers" here. Contact whoever created it for issues with those. I'm not sure I even understand the point, I guess they are for someone who wants to setup a package for a single OS (MacOS)?
Also we don't support so called "abandonware" here so if that's what your plan is then go elsewhere.
wrote:I don't know if there are wrappers that are set up with the latest version.
If you mean front ends, yes, I believe they work with newer versions of DOSBox.
https://www.dosbox.com/wiki/DOSBoxFrontends
Good news, folks! I finally got Battlespire's resolution problem taken care of! I simply changed the wrapper's resolution to 800x500, and now Battlespire's a perfect 4:3 ratio from top to bottom without taking anything away from the other games in the wrapper. Thanks for all the help everyone's given me. There's just one other problem I need to take care of, but I'll save that for another thread.
By the way, DosFreak, I bought Battlespire legally on GOG. I never said anything about it being abandonware.
