Problem with ANSI characters in real DOS through DOSBox
First post, by nlum
Hi,
I hope this is the right section (if not I'm sorry).
I have some problems displaying ANSI characters in MS-DOS 5.0 running inside DOSBox.
For example, if I run DOSMid in DOSBox I see this:
5.01 KiB
In MS-DOS installed inside DOSBox, I see this:
5.33 KiB
The same applies with ANSI characters in batch menus.
I tried adding DEVICE=C:\DOS\ANSI.SYS /X in CONFIG.SYS but it didn't solve the problem.
Is there something I can do to display those characters?
Maybe it's very simple to correct but I really don't know how to do it.
Any help would be greatly appreciated.
Thank you
Reply 3 of 4, by nlum
Thank you very much.
So I just have to change the codepage in my dosbox.conf, right?
I'm a newbie, forgive my ignorance.
_______________
Well, the problem was in the MS-DOS codepage, I solved it using this guide:
https://docs.oracle.com/cd/E19085-01/pci1.car … cdf8/index.html
I was looking at the wrong direction, thank you guys for your precious help.
